Date/Time: Thu, 15 Oct 2026 03:49:13 +0000
Draw Volume Profile not working
View Count: 1251
[2021-12-07 16:20:23]
12VMan - Posts: 58
When I use Draw Volume Profile, nothing is drawn. I subscribe to package 11 (also use Rithmic) so not sure why this is not working?
Thank you
[2021-12-07 18:54:48]
John - SC Support - Posts: 48209
The first thing we want you to do is to select a fairly large area when using the Draw Volume Profile tool, and see what you get as a result. If it is still not showing, then please get us a screenshot of what you are seeing. You can take a screenshot using these instructions:
Then also get us a copy of your Message Log if it is not working by following these instructions:
[2021-12-08 20:36:05]
12VMan - Posts: 58
Screenshot is blank b/c nothing happens when I try to draw the box for the profile/ I see the box, but when I click to indicate I'm done drawing, no prfile is drawn/ Link: https://www.sierrachart.com/image.php?Image=1638995657933.png
Message log:
Created the DTC Protocol server. | 2021-12-08 15:28:10.471
DTC Protocol Server listening on port 11099. | 2021-12-08 15:28:10.481
Reading Internal Order ID file. | 2021-12-08 15:28:10.482
Reading Trade Orders file. | 2021-12-08 15:28:11.184
Reading Trade Positions file. | 2021-12-08 15:28:11.185
Reading Trade Account Data files. | 2021-12-08 15:28:11.185
UDPListener (2012). Port 22904 | Listening on UDP port 22904. | 2021-12-08 15:28:11.279
Software version: 2328 64-bit | 2021-12-08 15:28:11.279
OpenGL enabled (NVIDIA Corporation/Quadro P620/PCIe/SSE2) | 2021-12-08 15:28:11.281
Primary Thread ID: 9884 | 2021-12-08 15:28:11.281
Usage end date: 2021-12-20 | 2021-12-08 15:28:11.281
Enabled for: Advanced Features 2. | 2021-12-08 15:28:11.281
Enabled for: Sierra Chart Historical Data Service. | 2021-12-08 15:28:11.281
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-12-08 15:28:11.281
Enabled for: Delayed Denali Exchange Data Feed. | 2021-12-08 15:28:11.281
Enabled for exchange2: CME (Trading Account Required) | 2021-12-08 15:28:11.281
Enabled for exchange2: CBOT (Trading Account Required) | 2021-12-08 15:28:11.281
Enabled for exchange2: COMEX (Trading Account Required) | 2021-12-08 15:28:11.281
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-12-08 15:28:11.281
Enabled for exchange2: fairx_exchange.data | 2021-12-08 15:28:11.281
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-12-08 15:28:11.281
Current selected Data/Trading service: Trading Evaluator | 2021-12-08 15:28:11.281
Custom symbol settings values: enabled | 2021-12-08 15:28:11.281
Chart Update Interval: 400 | 2021-12-08 15:28:11.281
Intraday Data Storage Time Unit: 0 | 2021-12-08 15:28:11.281
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-12-08 15:28:11.281
2021-12-08 20:28:11 Local computer time in UTC | 2021-12-08 15:28:11.281
2021-12-08 15:28:11 Local computer time in SC Time Zone | 2021-12-08 15:28:11.281
2021-12-08 20:28:09 Server time in UTC | 2021-12-08 15:28:11.282
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-12-08 15:28:11.282
Program path: D:\SierraChart\ | 2021-12-08 15:28:11.282
Data Files path: D:\SierraChart\Data\ | 2021-12-08 15:28:11.282
OS Version Number: 10.0 | 2021-12-08 15:28:11.282
Locale Setting: C | 2021-12-08 15:28:11.282
DLLs: LudwigLevels_2151_64.dll, OrderFlowLabs.com.beta_64.dll, OrderFlowLabs.com_64.dll, PullStack_64.dll, UserContributedStudies_64.dll | 2021-12-08 15:28:11.282
Allowed protected custom studies: Ludwig Levels, MQ Momentum Trender Pro, OrderFlowLabs.com, OrderFlowLabs.com Beta, PullStack, ValueCharts - MQ Momentum, ValueCharts - MQ Trend, ValueCharts Indicator, ValueCharts Ultimate | 2021-12-08 15:28:11.282
(removed)
Date Time Of Last Edit: 2022-01-18 01:13:59
[2021-12-08 22:39:55]
Since there are custom studies on that chart, we want you to start with a new chart with no other studies on it, then try using the Draw Volume Profile tool and let us know if it works or not.
If you do not see the profile, then we want you to go to Analysis >> Studies and see if the VbP is listed in there. Let us know.
[2021-12-10 02:25:46]
12VMan - Posts: 58
There are no studies in the chart I provided the link for. I do see VbP listed.
[2021-12-10 12:16:08]
12VMan - Posts: 58
I figured it out. The profile was the same color as my chart background. Very strange because it used to be visible via different color settings and I've never changed them.
[2021-12-10 17:00:42]
We are glad you figured it out. We do not know why the colors would have changed.
