Date/Time: Tue, 04 Mar 2025 09:21:47 +0000
Sierra Chart Changes Simulation Mode when Submitting Order
View Count: 524
[2021-12-07 14:06:19]
Thibaut Lartigue - Posts: 8
everything is on the title and I assume that you often deal this question. My broker AMP fed back that from their side, everything is ok. I've selected SC data - All services.
Yet, when I select CQG which is a data accepted by AMP, all is fine, however, I would rather like to have Denali data.
Thanks for your return.
Best regards
Date Time Of Last Edit: 2021-12-07 19:29:42
[2021-12-07 17:55:06]
John - SC Support - Posts: 38341
Sierra Chart is setup to allow you to get our data and trade with your broker. As such, you need to setup your software to connect to CQG, but as long as you have the Denali Exchange Data Feed active, you will get your data from us.
Refer to the following for more information:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
Also, if necessary, refer to the instructions to setup the connection to CQG at the following link:
CQG Trading Platform Service: Setup Instructions
