Date/Time: Tue, 04 Mar 2025 09:20:32 +0000
[User Discussion] - spreadsheet cell with a custom button
View Count: 614
[2021-12-07 10:03:48] |
Ferenc Reischig - Posts: 11 |
Hello, It is possible to change the formula of a spreadsheet cell with a custom button? thanks |
[2021-12-07 17:24:03] |
John - SC Support - Posts: 38341 |
Not using any of the built-in tools within Sierra Chart. There are a few customers that like to use software that allows for keyboard customizations, so there may be something out there that would work for what you want. We have set this as a User Discussion for other users to give their opinions and thoughts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
