Date/Time: Thu, 21 Nov 2024 10:16:20 +0000
Alerts
View Count: 588
[2021-12-06 17:33:12] |
Steve Leon - Posts: 301 |
I am trying to set up two alert sounds on time and sales for volumes over a certain amount i am using settings menu from time and sales the problem i am having is that i cannot get two different alert sounds for some reason no matter what alert sound i select it gives me the same sound which is a "ding" sound Thank you Steven Leon |
[2021-12-06 19:06:18] |
John - SC Support - Posts: 36174 |
Do you have the Alerts themselves setup to have different sounds? Refer to the following: General Settings Window: Configuring Alert Number Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-06 22:49:37] |
that was the missing piece Thank you Steven Leon |
[2024-11-20 18:43:36] |
Gtrader510 - Posts: 72 |
I have similar issue can you help to solve it please can't figure it out what to do. thank you |
[2024-11-20 19:09:26] |
Gtrader510: We need specific information on the problem you are having. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-20 19:45:17] |
I figured it out John thanks for replying appreciate
