Date/Time: Tue, 26 Nov 2024 02:35:16 +0000
Sieraa data service
View Count: 1194
[2014-04-03 09:56:18] |
User54027 - Posts: 128 |
Hello support, I currently have your package 3 subscription and am using the fxcm data feed. Please could you advise me on the additional cost of using your new Sierra data feed on the following markets only: US30 ( Dow Jones index) GER30 ( German Dax Index) USDJPY ( US Dollar / Japanese Yen forex pair) Many thanks. |
[2014-04-03 10:13:12] |
The new Sierra Chart data feed is an exchange data feed. These particular symbols are Forex and CFD symbols. They are included with package 3. There is no additional charge. You will see them listed in File >> Find Symbol. Press delete? You just need to select the symbols and open charts for them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-03 10:46:19] |
I understand...but the data feed from fxcm is limited. I need actual data to run analysis on...for example your new offering on High Frequency Footprint cannot function from an fxcm data feed. |
[2014-04-03 17:34:42] |
So would you need futures data ? It gets expensive to get futures data if you do not have a futures trading account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-04 13:53:23] |
Yes, I would need futures data.
[2014-04-04 16:42:57] |
Do you have a futures trading account? If not, then you will need to use IQ Feed: https://www.sierrachart.com/index.php?l=doc/DTNIQFeed.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
