Date/Time: Tue, 04 Mar 2025 09:36:13 +0000
CONNECTION COMPTE TRADING PLATEFORME SIERRASbonjour
View Count: 682
[2021-12-06 15:13:09]
REMI MILANDE - Posts: 10
hello I come to open an account with amp future I would like to connect my tranding account on the sierras platform can you help me?
[2021-12-06 17:22:08]
John - SC Support - Posts: 38341
The instructions you will need to follow will depend on the Order Routing Service that AMP has set you up to use.
If you are setup with CQG, then you will use these instructions:
CQG Trading Platform Service: Setup Instructions
If you are setup with Rithmic, then you will use these instructions:
Rithmic Trading Platform Service: Setup Instructions
[2021-12-07 14:21:51]
i just want to connect my account with denaly feed?
[2021-12-07 14:23:19]
BECAUSE IN THE INSTRUCTION I DO NOT SEE THE PROCEDURE FOR DENALY ?
[2021-12-07 17:58:53]
Sierra Chart is setup to allow you to connect to your broker for trading and get the data from us. Therefore, you just need to go through the appropriate instructions as we noted above to connect to your AMP trading account, and you will continue to get the data from our Denali Exchange Data Feed.
For more information on this, refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
