Date/Time: Tue, 18 Feb 2025 22:51:26 +0000
COLORIZED ZONE BETWEEN TENKAN AND KINJUN
View Count: 1269
[2014-04-03 07:39:06] |
User45578 - Posts: 50 |
How olorizing zone between TENKAN SEN and KINJUN SEN?Green when Tenkan < A Kinjun and red the contrary?
[2014-04-03 16:13:08] |
M5amhan - Posts: 468 |
first you need to use the source code to combine the two studies into one.. you can do this by just copy and paste. there is documentation on how to build advanced custom studies & the source code is in the ACS Source file located in your sierra chart folder then you need to use the draw style: Trans. Fill Bottom & Trans. Fill Top I used the study Moving Averages to show you an example in the attachment |
[2014-04-05 00:12:08] |
We need to review the documentation for this and it will be updated and we will post a link here when done.
[2014-04-05 00:36:17] |
Sawtooth - Posts: 4173 |
Here's how to do it with an existing study: Add the Study Subgraphs Reference study. -Set the Chart Region to 1 -Set the Scale to Automatic -Check 'Draw Study Underneath Main Price Graph' -Set the Input Study1 to the Tencan-Sen study -Set the Input Study2 to the Kinjun-Sen study -Set the SG1 Draw Style to Fill Top (this is the Tenkan > Kinjun color) -Set the SG2 Draw Style to Fill Bottom (this is the Tenkan < Kinjun color) Date Time Of Last Edit: 2014-04-05 00:57:03
[2014-04-08 02:07:00] |
Here is the updated documentation for how to do this: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#FillingArea Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
