Date/Time: Sat, 12 Sep 2026 23:36:04 +0000
[User Discussion] - Buy Stop/Sell Stop: Buy High/Sell Low Shortcut Key
View Count: 1551
[2021-12-05 22:44:36]
User94606 - Posts: 327
Is there a way to setup a shortcut key to send a Buy Stop/Sell Stop order when the high/low of the "previous bar" is taken out?
[2021-12-08 13:55:35]
Any updates?
[2022-03-06 08:06:51]
aseef - Posts: 55
I really need these buttons in trade window as they are critical for scalping. Can you please make it happen. I have checked almost every third part developers no one has it.
I am giving a try to Sierra charts these days and currently use Ninja, without having this I will not be able to switch. There are plenty of addons/indictors for this type of order execution.
[2022-03-06 22:53:26]
IconBob - Posts: 61
I have a study I developed that auto submits orders based on hi-lo open of bars.
https://1drv.ms/v/s!Ag7ig35aJhHihMIDTY-ZNnXj244nzQ?e=dwFlpK
[2022-03-06 22:59:20]
aseef - Posts: 55
I cant open this study following error message received
{"error":{"code":"generalException","message":"General Exception While Processing"}}
[2022-03-06 23:05:03]
IconBob - Posts: 61
did you copy the entire URL for some reason Sierra didn't highlight the entire URL (Link)
[2022-03-06 23:10:49]
IconBob - Posts: 61
I attached the file
attachment2022-03-06_17-46-22.mp4 - Attached On 2022-03-06 23:09:15 UTC - Size: 1.41 MB - 429 views
[2022-03-06 23:36:01]
aseef - Posts: 55
I got it.
Yes this is exactly that I am looking for...Thanks for sharing.
How can I have this?
Date Time Of Last Edit: 2022-03-06 23:36:28
[2022-03-06 23:38:25]
aseef - Posts: 55
Can we assign the keyboard short cut also to these keys?
Date Time Of Last Edit: 2022-03-06 23:38:40
[2022-03-07 13:56:51]
IconBob - Posts: 61
No, this doesn't meet your requirements.
[2022-03-07 15:10:56]
aseef - Posts: 55
Thank you so much, Can I give it a try?
