Date/Time: Tue, 04 Mar 2025 07:30:24 +0000
Datos en tiempo real
View Count: 780
[2021-12-03 15:18:19]
Monkey.D.Luffy - Posts: 4
Buenos dias.
Tengo el paquete de servicios N5, se supone que dentro de dicho paquete deben de entrar los datos en tiempo real.
Le comento porque en todos los graficos me sale el apartado (delayed)
Me gustaria saber como hacer para obtener los datos en tiempo real de CME como Nymex, si es otro paquete o hay que realizar cualquier otra opcion les agradeceria que me comentara como hacerlo.
Un saludo y gracias por su tiempo.
[2021-12-03 17:14:41]
John - SC Support - Posts: 38341
From Google Translate:
Hello.
I have the service package N5, it is assumed that within this package the data must enter in real time.
I comment because in all the graphics I get the section (delayed)
I would like to know how to get the real-time data from CME as Nymex, if it is another package or if you have to perform any other option, I would appreciate if you could tell me how to do it.
Greetings and thanks for your time.
To get the real-time data you need to pay for it. As such, you would need to go through the Setup Instructions at the following link to get the data:
The costs and other information are on that same page.
