Date/Time: Tue, 04 Mar 2025 07:34:36 +0000
Exporting Control Bar panel settings to other PC
View Count: 533
[2021-12-03 14:02:24] |
User361939 - Posts: 167 |
Hello, I build Control Bar panel 2. I would like to have it on other PC. Which file should i copy so it will look the same on other PC? Best Regards |
[2021-12-03 16:47:50] |
John - SC Support - Posts: 38341 |
The file is called the following: Sierra4.config The file is located in the main Sierra Chart folder. The location of this folder is dependent on where you had originally installed Sierra Chart. You can find the location by opening Global Settings >> General Settings and looking at the Data Files Folder entry, where the main Sierra Chart is one folder level up from the Data folder. Note that by copying the Sierra4.config file, you will be updating all of your configurations, which means not only Control Bars, but colors as well. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
