Date/Time: Thu, 06 Mar 2025 09:50:36 +0000
Symbol Price Alert Show on Chart
View Count: 681
[2021-12-03 10:30:53]
User379468 - Posts: 508
Could it be possible to show the symbol price alerts as lines on a chart to easily move/manage them visually?
[2021-12-03 16:02:37]
John - SC Support - Posts: 38425
We are not sure exactly what you want to do, but you would have to use the Spreadsheet Study to create a line based on a set of conditions.
[2022-01-18 22:53:24]
As of now it is simple and easy to create a symbol price alert at a specific price on the chart via the chart shortcut menu. This alert can then be viewed in the Alert Manager. I would simply like to be able to view the actual alert at it's given price on the chart like most other platforms like Thinkorswim or TradingView support and manage/move it from the chart. Could you consider adding this?
[2022-02-01 02:08:20]
On TradingView you can also add a price alert easily on a study like a moving average, it's really quick, easy, and useful just with a mouse click and it appears visually on the chart. Is it possible to add this to SC?
[2022-02-01 15:06:20]
The only way to get the line as you are wanting would be to use Spreadsheet Study rather than the Symbol Alert. Then set your condition in the Spreadsheet and have the result being true for the bars where you would want the line to be drawn.
We can't say when or if this will happen, but we have set this as a Feature Request.
