Date/Time: Tue, 04 Mar 2025 07:44:03 +0000
New User
View Count: 457
[2021-12-03 04:07:50] |
User946129 - Posts: 15 |
Hello, When I signed up for free trial, it said it was restricted. Nevertheless, my intent, at least to start out is to have: 1) real time charting for all stocks 2) I do need real-time data from Sierra for all stocks Can you kindly direct me to which package I need to sign up with? I will consider other instruments, including futures, at a later time. Many thanks, A.S. |
[2021-12-03 07:39:41] |
Your Sierra Chart account is now active. For real-time data for US stocks you need to use the Sierra Chart Exchange Data Feed and activate the US Equities Exchange: Sierra Chart Exchange Data Feed You can use this data feed with any Sierra Chart service package. You can start with Service Package 3 (Standard). For Sierra Chart pricing, refer to this page: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-03 07:41:04
