Date/Time: Tue, 04 Mar 2025 07:44:03 +0000
[Programming Help] - Showing extended hours chart on the composite chart
View Count: 490
[2021-12-03 01:51:45] |
amazayn - Posts: 48 |
Is there anyway to just show the current after hours composite profile on the attached comp profile chart? I'd like to see what happens on this chart overnight.
[2021-12-03 15:28:08] |
John - SC Support - Posts: 38341 |
You would have to set the Volume Profile as a separate study and set the Input for Volume Graph Period Type to One Period from Start Time to End Time and then enter the times for which you want the profile in the Start Time and End Time Inputs. Refer to the the information for these Inputs starting here: Volume By Price Study: Volume Graph Period Type For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
