Date/Time: Fri, 30 Oct 2026 16:03:39 +0000
Time range highlight on currency market
View Count: 830
| [2021-12-02 16:28:32] |
| User525965 - Posts: 180 |
Hi, I use the time range highlight (transparent) on all my trading charts. For some reason though, it will not highlight on my currency charts. I saved the template that works fine on other markets and applied it to my currencies and it doesn't work. Also, I do have the currencies set for day and evening sessions in the chart settings, just in case that was the problem, but that did not fix it. thanks |
| [2021-12-02 18:33:05] |
| John - SC Support - Posts: 48369 |
It really does not make any sense that there would be any dependence on the instrument type. Please attach a chartbook that has one of the currency charts that is not working for us to take a look at it. Follow these instructions to attach the chartbook: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-12-02 23:33:11] |
attached
| [2021-12-03 00:28:33] |
For this chart, the problem is that the Subgraph Draw Style is not correct. It was set to Transparent Fill Rectangle Top. Refer to the following: Chart Studies: Subgraphs Tab >> Draw Style For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
