Date/Time: Tue, 04 Mar 2025 08:01:59 +0000
changing my sim trading default amount
View Count: 457
[2021-12-02 15:44:21] |
User856350 - Posts: 34 |
how do i change the default amount of shares in my sim trading? thank you |
[2021-12-02 17:47:49] |
John - SC Support - Posts: 38341 |
If you are asking how to change the quantity, then refer to the following: Basic Trading and the Trade Window: Main >> Order Quantity (Quantity) Whatever you set the quantity to will stay at that quantity until you change it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
