Date/Time: Thu, 26 Dec 2024 04:42:56 +0000
Chart Settings
View Count: 846
[2014-04-02 20:41:26] |
User94740 - Posts: 333 |
Hi SC, I am wondering if it is possible to have the day and evening sessions separated. This would mean I would have a bar for the day session and a separate bar for the evening session. thx!
[2014-04-03 05:43:04] |
Not sure if this would work or not. The relevant setting for this would be the New Bar at Session Start setting in Chart >> Chart Settings.
[2014-04-03 05:48:04] |
I have tried it, but it fails to produce the desired result.
[2015-12-08 18:43:13] |
I am wondering if it is possible to change the chart number.
