Date/Time: Tue, 04 Mar 2025 07:49:57 +0000
Indexes
View Count: 765
[2021-12-02 15:13:17] |
LucentTrader - Posts: 35 |
What subscriptions or exchanges are required for the following symbols. Description: Total Put/Call Ratio Symbol: $CPC Description: Index Put/Call Ratio Symbol: $CPCI Description: Equity Put/Call Ratio Symbol: $CPCS Description: Total Call/Put Ratio Symbol: $PCP Description: Index Call/Put Ratio Symbol: $PCPI Description: Equity Call/Put Ratio Symbol: $PCPS Description: Bond Put/Call Ratio Symbol: $CPCB Description: Bond Put/Call Ratio Symbol: $PCPB |
[2021-12-02 17:07:24] |
John - SC Support - Posts: 38341 |
These are part of the CBOE Indices exchange. To get this data, you need to use the Sierra Chart Exchange Data Feed and activate the CBOE Indices. Refer to the information at the following link, which also includes the Setup Instructions: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-02 18:16:49] |
I am currently subscribed to the CBOE indices. I do not get these symbols data or quote.
[2021-12-02 19:30:58] |
We will have to check with our provider for that data to see what is happening with those symbols.
[2021-12-02 19:55:50] |
Additionally I am not getting data for V9Y2000 - Value Line Geometric and YVY2000 - NYSE Composite Index. I am subscribed to the indices.
[2021-12-03 14:56:09] |
Our provider for this data (Barchart) is taking care of making this data available for your account. It should be done today sometime.
