Date/Time: Tue, 04 Mar 2025 06:30:56 +0000
horizontal lines
View Count: 457
[2021-12-02 14:31:47]
George Slezak - Posts: 38
The horizontal lime study has inputs for 59 lines, only 29 will display.
can you make it so comma separated numbers can be entered and those would go to the inputs
can you make more than 59 inputs, ie 100 or 200?
[2021-12-02 16:31:55]
John - SC Support - Posts: 38341
We just tested to ensure there was nothing wrong with the study and we are able to put more than 29 lines. Make sure you have the Subgraphs for lines greater than 29 set to display as lines (or other option) under the Subgraph settings. Refer to the following:
Chart Studies: Subgraphs Tab >> Draw Style
59 is the maximum number of lines that can be drawn with this kind of study, as we only support 60 subgraphs. You could do what you want as a custom study where the lines are drawn as drawings rather than as subgraphs.
