Date/Time: Tue, 04 Mar 2025 06:59:17 +0000
denali cme
View Count: 502
[2021-12-01 16:15:43] |
Don H - Posts: 31 |
Hi. Have and am subscribed to the Denali feed and would like to add CME non-professional live status. When I go to try message comes up reading feed not enabled but when I go into global settings says is enabled. Not sure what to do, want to add the real time CME to existing Denali feed. thanks
[2021-12-01 17:34:46] |
John - SC Support - Posts: 38341 |
In general, to add the real-time data for the CME, you need to follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* But, before you go through that, be sure you understand the CME Group's requirement that you have a live, funded, futures trading account that you can connect to at least once a month in order to qualify for the non-professional exchange fees. You will find more information on this here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
