Date/Time: Fri, 02 Oct 2026 21:43:13 +0000
[Locked] - Historical data not loading fully
View Count: 764
[2021-12-01 15:06:48]
User529087 - Posts: 25
Hi
I just signed up with a funding brokerage school. They use Rhythmic so I had to switch for the moment.
I reduced the package from 12 to 10.
SP 10 is the minimum I need for rhythmic correct?
I can tell you the Denali feed is better wright away, will come back to it.
When I load a chart after reading the connection guide for rhythmic putting all the info, the charts only load the current data and build from there, how can I load at least a month prior or data?
Thank you for your assistance.
[2021-12-01 16:30:22]
John - SC Support - Posts: 48095
Refer to the following:
Historical Data on the New Rithmic Connection
