Date/Time: Mon, 23 Dec 2024 07:29:49 +0000
Compiler Error
View Count: 1089
[2014-04-02 18:47:45] |
User83762 - Posts: 61 |
When using "Build Custom Studies DLL, I get a windows error: g++.exe has stopped working. I've tried deleting the compiler folder and reinstalling. Please advise.
[2014-04-02 21:22:13] |
Not really sure what help we can provide with this. We do not observe this or have other reports of this and the compiler is not a program that we develop ourselves. Other than deleting and reinstalling the compiler, our only other advice is to use Microsoft Visual C++: https://www.sierrachart.com/index.php?l=doc/doc_VCExpress.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-23 11:43:36] |
User634832 - Posts: 2 |
I have the same issue. The reason appears to be: Cannot create temporary file in C:\Windows\: Permission denied I am on a work PC and don't have permission to access C:\Windows folder. How can I repoint the compiler to use a different temporary folder instead ? Thanks! |
[2015-09-23 18:39:13] |
We wish we were able to help with this but we did not develop that compiler. This is the website for it: http://mingw.org/ So we do not know the answer to this question. It is not good that it has a dependency on the Windows folder. You could use Visual C++: https://www.sierrachart.com/index.php?page=doc/doc_VCExpress.php Or you can use your own separate computer without this limitation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-23 18:41:39
