Date/Time: Tue, 04 Mar 2025 07:57:07 +0000
big lag in using DOM to trade - CQG
View Count: 757
[2021-12-01 00:22:45]
User811622 - Posts: 38
I'm using CQG for order routing. My Sierra Chart DOM has a lot of lags and pauses. Data jumps. I contacted AMPfuture. They said no one else has issue so it must be specific to my Sierra Chart. Please help.
[2021-12-01 05:05:12]
First thing to do is to implement what is explained here:
Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading
If that does not help, use the Denali Exchange Data Feed:
Date Time Of Last Edit: 2021-12-01 05:05:26
[2021-12-01 16:13:02]
Would you be so kind and do remote session with me? To make sure it's not Sierra chart itself? Thank you so much.
[2021-12-02 22:36:48]
Sierra_Chart Engineering - Posts: 18641
The first thing we want you to do is to install a second installation of Sierra Chart. Instructions:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
And use the Delayed Exchange Data Feed and see how that works for you:
The data is delayed, but is still it is a valid test to see if the issue is related to the data feed itself.
