Date/Time: Tue, 04 Mar 2025 07:26:11 +0000
Enable DTC Protocol Server | reverts to 'No' on apply
View Count: 735
[2021-11-30 22:34:20]
User594405 - Posts: 5
Latest version. Can't get data into a sub instance, target machine actively refused connection.
Main instance, Sierra Chart Server Settings, Enable DTC Protocol Server is No. Setting to yes and hitting Apply All changes it back to 'No'.
Windows Server 2019 Standard
Date Time Of Last Edit: 2021-11-30 22:34:41
[2021-11-30 23:00:38]
That does not make sense. There is no functionality that does this:
Update:
Check the listening port. If there is an error listening , the server will be disabled. The Message Log shows this.
Date Time Of Last Edit: 2021-11-30 23:02:41
[2021-11-30 23:37:43]
You are correct.
Listening socket (1536). Port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10013: An attempt was made to access a socket in a way forbidden by its access permissions. | 2021-11-30 17:37:02.928
Running the Sierra process with Administrator permissions does not resolve the error. Will dig...
Date Time Of Last Edit: 2021-11-30 23:42:39
[2021-11-30 23:44:16]
Workaround:
Use a port that is not included in the default dynamic port range (from 49,152 to 65,535),
