Date/Time: Tue, 04 Mar 2025 07:44:01 +0000
Advantage Future + Sierra Chart Direct Order Routing Set-up
View Count: 642
[2021-11-30 18:22:01] |
User193762 - Posts: 13 |
When going through the set-up instructions below for Sierra Chart Direct Order Routing I get this "Trade account not assigned" I contacted my broker Advantage Futures. Did I make the right move? Sierra Chart Teton Futures Order Routing: Setup Instructions I've contacted Advantage Futures and it looks like they have done their part. Could you please activate or connect CME direct routing? *Also Under trade account monitor still shows the account number from AMP. Do I need to remove that? if so how? |
[2021-11-30 18:24:38] |
Sierra_Chart Engineering - Posts: 18641 |
For the Clearing Firm select "Advantage" and not "Advantage/Stage 5". If you still cannot connect we will call Advantage. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
