Date/Time: Tue, 04 Mar 2025 08:00:32 +0000
way to spread out numbers in number bars study?
View Count: 550
[2021-11-30 18:18:49]
HeyUgly - Posts: 251
pic attached. i have my candle stick on a 3 width lol, is there anyway to spread the numbers out side x side so they are not so close??its very tough to read so close together
imageCapture7.PNG / V - Attached On 2021-11-30 18:18:31 UTC - Size: 3.64 KB - 149 views
[2021-11-30 18:35:39]
John - SC Support - Posts: 38341
Refer to the following input:
Numbers Bars: Numbers Separator Character
[2021-11-30 20:56:04]
JohnR - User831573 - Posts: 317
You might also be able to use a different font or style/size that is more spaced out. But - Then you might have to also widen your bar spacing on the chart or the vertical price range of the chart.
JohnR
