Date/Time: Tue, 04 Mar 2025 07:56:21 +0000
Difference in Volume between TPO TV and DailyChart Volume study
View Count: 478
[2021-11-30 15:10:49]
Stephan_CH - Posts: 18
Dear SierraChart Support
Why there is such a big difference in volume numbers between TPO chart value "Total Volume" and daily chart Volume study per day? I notice that in alle future markets
In example you can see on attached picture KCH22 total volume is 23697 for 29th of November 2021 and beside for the same day on daily chart volume study with volume 31146 for the same day. The value on daily chart is the same like on quote board displayed and is almost the same day trading value on Barchart.com published (31'186 for 29/11/2021). But volume on TPO ist totally different.
Is there any mistake on my side or is there any other explanation for the difference?
Thanks a lot for your support.
Kind regards, Stephan
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=57562
[2021-11-30 17:12:37]
John - SC Support - Posts: 38341
Refer to the following:
Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume
