Date/Time: Tue, 04 Mar 2025 07:54:44 +0000
range bar (true(in Ticks))
View Count: 972
[2021-11-30 14:57:29] |
User149559 - Posts: 3 |
I notice that with this setting, the bar often goes beyond the desired ticks and then resets to make it look like it started or stopped the bar at the tick amount I have set. How do I get this to be more accurate. My current strategy depends on this being accurate.
[2021-11-30 15:00:36] |
Refer to: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent: Last Bar in Chart Exceeding Range Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
