Date/Time: Tue, 04 Mar 2025 07:32:07 +0000
Multiple Trade accounts
View Count: 448
[2021-11-30 13:35:13] |
PlainCheesePizza - Posts: 17 |
Hello, I tried looking for a direct answer to this myself but found murky responses so I want to confirm. I have the following - personal trading account with transact - a trading combine with topstep for Sierra Do I need to install another version on SC on my local disk in order to be able to open SC normally and have my DOM for transact up and also have a DOM for topstep (rithmic) up? |
[2021-11-30 16:25:52] |
John - SC Support - Posts: 38341 |
Yes, it is best to have two installations on the same computer in order to have one connected to Rithmic and the other to TopStep, assuming that you are wanting to trade from both of them during the day. Refer to the information at the following link for how to install another Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
