Date/Time: Sat, 13 Sep 2025 04:29:16 +0000
horizontal line at time - no straight line
View Count: 952
[2021-11-30 13:15:04]
User12089 - Posts: 380
the studies horizontal line at time and high/low for time period - can not draw a straight line ONLY. The line drawn appears as "stair step line" specifically between the end of the previous time period and start of the new time period
The above results in somewhat ugly and more to the point redundant vertical lines, unnceerily cluttering the chart. Anyway to suppress the vertical lines ? I did try switching from the default "stair step line" to just "line" but that didnt have any effect on the vertical lines - ie the plots were still "stair step"
[2021-11-30 13:19:33]
User907968 - Posts: 844
Try using 'Dash' drawstyle instead.
[2021-11-30 13:40:46]
thank you but no change
this is a bug in the two two studies mentioned above and needs to be fixed
[2021-11-30 14:10:23]
Are you sure? See attached images, no vertical line...
imagehigh-low-for-time-period.png / V - Attached On 2021-11-30 14:09:30 UTC - Size: 107.39 KB - 195 views
imagehorizontal-line-at-time.png / V - Attached On 2021-11-30 14:09:46 UTC - Size: 105.59 KB - 203 views
[2021-11-30 14:54:59]
yes still getting stairstep lines instead of just lines on range bar charts (dont use any other type of bars) even when using a dashed line style
[2021-11-30 15:02:06]
Not dashed 'line style' - Drawstyle Dash >>>> Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH)
I am also using range bar charts with these studies.
Date Time Of Last Edit: 2021-11-30 15:02:55
[2021-11-30 15:16:08]
indeed it has worked. Thank you for the additional efforts/clarifications/time to point out that there was also Drawstyle "Dash" besides linestyle "Dash"
