Date/Time: Tue, 04 Mar 2025 07:54:44 +0000
Change to two digit year format
View Count: 524
[2021-11-30 04:08:10] |
User496841 - Posts: 1 |
I bought a new computer. I am attempting to copy my numerous chart setups over to the new computer. It did not work because now it appears as though you require two digits for the year, i.e., instead of the chart symbol being MESZ1, it is now MESZ21. Does this mean I have to re-build all my complex charts from scratch because of the new symbol requirements of two digits? Is there a work-around? How about rollover next month? Will the system roll from MESZ1 to MESZ22? Is there an automated way to deal with this? Thanks |
[2021-11-30 08:53:13] |
This depends upon the particular service being used: Data/Trading Service Connection and Symbol Issues: 1.3. Symbols And there is a way to automatically translate the symbols: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
