Date/Time: Tue, 04 Mar 2025 06:56:01 +0000
Drawing rectangles with some automation
View Count: 814
[2021-11-30 03:36:17] |
User540050 - Posts: 7 |
I am hoping someone can help me either find or make or adjust a setting. I want to be able to draw an extended rectangle that stops when price returns to it. Sort of like on touch. Is this currently possible?
Private File |
[2021-11-30 15:22:24] |
John - SC Support - Posts: 38341 |
You would have to program this such that you were drawing an extended rectangle, and then check if the price intersects and when it does, change the extending rectangle to a standard rectangle with the end anchor point at the index at which the price intersected. Refer to the following for programming information for drawing tools: Using Drawing Tools From an Advanced Custom Study You might be able to do what you want with the Spreadsheet Study and using the Fill options to create a filled area between two lines. We have not worked this out to say that it could be done, but it is something that you could try to do this way. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-02 12:59:21] |
Is there a way in any of the settings to manually stop an extended rectangle or convert it to a rectangle? or is the only native solution to draw a rectangle over the extended and then delete the extended? thanks so much for your help |
[2021-12-02 13:01:57] |
Cut Drawing here. I found it.
