Date/Time: Tue, 04 Mar 2025 07:25:19 +0000
Rithmic Direct Connection
View Count: 478
[2021-11-30 00:17:21] |
User487012 - Posts: 1 |
I am not able to connect to my Rithmic account using Sierra. It shows (Not enables on package)
[2021-11-30 03:02:18] |
Your Sierra Chart account is on the correct Service Package. We want you to restart Sierra Chart following these instructions: Sierra Chart - Software Login Instructions: Forced Login Let us know if you can then connect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
