Date/Time: Mon, 05 Oct 2026 23:55:45 +0000
Unsure About Datetime Functions and Values
View Count: 2005
[2021-11-29 13:24:19]
maxpi - Posts: 194
I have tick data in chart #6. The following code reports 0 for the value of LastDateTime. I wonder if the problem is in the calculations or the message. I believe that SCDateTime values should work in the log as floating point values but am unsure.
SCGraphData TickPriceData;
sc.GetChartBaseData(6, TickPriceData);
int tickArraySize =TickPriceData[SC_OPEN].GetArraySize();
SCDateTimeArray TickDateTimeArray;
sc.GetChartDateTimeArray(6, TickDateTimeArray);
SCDateTime LastDateTime;
LastDateTime =TickDateTimeArray[tickArraySize -1];
MessageText.Format("LastDateTime %f", LastDateTime);
sc.AddMessageToLog(MessageText, 0);
[2021-11-29 14:54:19]
This is definitely not correct:
You need to use this function:
ACSIL Interface Members - Functions: sc.DateTimeToString()
