Date/Time: Tue, 04 Mar 2025 06:44:13 +0000
GCG2 charts
View Count: 532
[2021-11-29 12:24:46] |
User739935 - Posts: 37 |
I clicked for rollover this morning... charts loaded but they are frozen not updating .my other charts are working fine
[2021-11-29 12:39:48] |
You are using Transact. First thing is refer to this help topic: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart And then contact Transact if you are not getting the data feed for a particular symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
