Date/Time: Tue, 04 Mar 2025 12:20:55 +0000
Symbol display - Listing exchange
View Count: 642
[2021-11-28 20:45:34] |
User860785 - Posts: 11 |
Hi Team - Is there a study to have the Listing exchange for equities added? Looking for something like <Listing Exchange>:<Symbol> or alternative. I looked under symbol display study and a search of the support board but couldn't find much. |
[2021-11-28 22:26:18] |
You can find the exchange in some cases in Global Settings >> Symbol Settings.
[2021-11-29 02:46:34] |
Any guidance on how to make that appear on the chart? I also looked at Global Settings >> Customize Chart Header for an Exchange field but couldn't find much. |
[2021-11-29 14:40:48] |
It is not accessible on the chart currently. We would have to add a new header field for that which we can do.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-29 14:40:55
[2021-11-29 22:15:35] |
Thank you. Do I put in a feature request or is this automatically added to your queue for consideration?
[2021-11-29 22:41:14] |
John - SC Support - Posts: 38341 |
It is automatically added to our list.
[2021-12-07 22:47:03] |
This has already been released.
[2021-12-11 00:17:51] |
Just wondering if you carry the Equity exchange for Equities in the data feed as its not showing when I add it under Customize Chart Header. Is it because I'm in free mode? |
[2021-12-11 00:29:42] |
Yes Sierra Chart does provide real-time US equities data if that is what you are referring to?
[2021-12-11 05:11:37] |
Hi, No; I wasn't clear. I tried adding the new 'Exchange' field using 'Global Settings >> Customize Chart Header' to my chart in my chart book. However there is no 'Exchange' field added to the chart header even though its selected. (I can modify other fields in the chart header) My question is: Is the Exchange field not showing on my chart header because a) my trial has expired and I need the realtime equity data to populate this field on my charts or b) Is the US Exchange field not populated for US Equities. Thank you |
[2021-12-13 15:21:26] |
The answer is a) you need to have an active account to be able to get any data into the system, therefore you are not seeing the field. Note that you do not need the real-time data, just an active account with the delayed data will work. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
