Date/Time: Tue, 04 Mar 2025 06:59:46 +0000
SC not responding
View Count: 556
[2021-11-28 14:39:01]
PlainCheesePizza - Posts: 17
Hello this weekend my SC has been very sluggish and constantly trying to re download historical data which then sends the program into a not responding state constantly. Is there some kind of Maintenace going on? I attached a log where I think I caught most of it
attachmentSC_Log_11-28.txt - Attached On 2021-11-28 14:37:52 UTC - Size: 64.27 KB - 246 views
[2021-11-28 14:51:52]
Here is another log from a restart of SC...it was completely locked up the entire time until I was able to execute a disconnect
attachmentSC_Log_v2.txt - Attached On 2021-11-28 14:51:43 UTC - Size: 205.83 KB - 269 views
[2021-11-28 16:16:59]
Transact is frequently disconnecting you:
TransAct WS | Received disconnect message on Orders connection. | 2021-11-28 08:31:37.963
Connection to the external service has been lost. | 2021-11-28 08:31:37.963
This is not something we can control but what we recommend you do is select File >> Disconnect to prevent further re-connections. However, a reconnection should not be causing any performance issue and if you are seeing that, you need to look at what the cause is. All of the known causes are here:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
For the best connectivity and to avoid any connectivity issues over the weekend, use this service:
Date Time Of Last Edit: 2021-11-28 16:18:09
[2021-11-28 16:38:56]
I fired up a different chart book and had no issues...do you see anything in that log that would indicate a setting on I have on a particular chart is mis configured ?
[2021-11-28 16:49:12]
It is not possible for us to determine something like that from the Message Log.
Date Time Of Last Edit: 2021-11-28 16:49:17
