Date/Time: Tue, 04 Mar 2025 04:18:05 +0000
[Programming Help] - Importing and using a DLL
View Count: 578
[2021-11-27 06:27:41]
KylieV1618 - Posts: 67
Im trying to import a sound library and use it.
I don't know much C++, so this might be really basic.
But I have
HINSTANCE SDL = LoadLibrary("SDL2_mixer.dll");
// Load file
Mix_Chunk *sample;
I get..
'Mix_Chunk' was not declared in this scope
If I do SDL.Mix_Chunk = *sample, I get...
request for member 'Mix_Chunk' in 'SDL', which is of pointer type 'HINSTANCE' {aka 'HINSTANCE__*'} (maybe you meant to use '->' ?)
Does this mean to use it I have to do something more? Like SDL.Mix_Chunk. Or SDL->Mix_Chunk. Ive tried both and neither work.
How do I get access to the Mix_Chunk that is inside SDL2_mixer.dll?
Date Time Of Last Edit: 2021-11-27 06:29:18
