Date/Time: Wed, 27 Nov 2024 02:21:25 +0000
Symbol not found in margin dataMargin requirement not known for symbol for EUREX
View Count: 791
[2021-11-26 07:26:26] |
JDen - Posts: 10 |
Hello, I am getting the error "Symbol not found in margin dataMargin requirement not known for symbol. Margin calculation < = 0. Invalid." when I try to place orders in the Trading Evaluator for EUREX symbols with the Denali data feed. I have tried updating the symbol settings from server and reconnecting but it won't solve the issue. I am subscribed to the EUREX feed and it has always worked until today. Many thanks, J. |
[2021-11-26 16:05:31] |
We are checking on this.
[2021-11-26 17:27:28] |
This has been resolved. We apologize for the issue. It relates to the implementation of using the actual EUREX margin rates which are now being used.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-26 17:28:28
[2021-12-07 01:14:41] |
User987654 - Posts: 69 |
Hi support, this is still happening with 6J (USDJPY) future using denali data feed and Trading Evaluator.
[2021-12-07 04:35:15] |
The reason for this particular issue for that symbol has a completely different cause. We need to find out why that is happening.
[2023-09-25 11:13:24] |
Tin43 - Posts: 90 |
I'm having the same issue with Ger30. CFD. Trading Evaluator - Delayed (Order reject). Info: Symbol is unknown for trading. Internal Order ID: 17206. Service Order ID: (none). Symbol: US30. Account: 5MINUTE | 2023-09-25 07:13:37.547 * And that error with US30.. Opps sorry... It's due trading simulation it's only in futures market? Date Time Of Last Edit: 2023-09-25 11:14:41
[2023-09-25 21:45:18] |
Sierra_Chart Engineering - Posts: 17190 |
CFD symbols are not tradable when using the Trading Evaluator.
