Date/Time: Tue, 26 Nov 2024 02:47:30 +0000
Problem with continous cotract
View Count: 1009
[2014-04-02 11:32:23]
golan_82 - Posts: 24
I have some problem with the settings I guess
Yestertay the ES made a new Daily High and in my chart there was not a new high , only
in 07/03/14
what should I do to see it properly?
I'm using 1077 version and OEC data feed
thanks
image1.jpg / V - Attached On 2014-04-02 11:32:20 UTC - Size: 499.13 KB - 365 views
[2014-04-02 16:22:41]
We no longer provide support for symbols that use the "#". Change the symbol of the chart to ESM14 following these instructions:
https://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html
Although the problem may not be with the symbol but with the OEC data feed.
Refer to information given in help topic 6:
https://www.sierrachart.com/index.php?l=doc/helpdetails6.html
[2014-04-03 10:23:44]
Thank you...
It's okay now , but still I have problem with the 240min chart
I also want it to be a continuous chart , is it possible or it is only made for daily/weekly and so on?
because this chart show me the price as 143.8 and not 1.4380 as it now shows in the daily charts
thanks
[2014-04-03 17:32:50]
To solve this problem you need to update Sierra Chart to the latest release. Here are the instructions:
https://www.sierrachart.com/index.php?l=doc/download.php#FastUpdate
Make sure the symbol settings are up to date following the instructions here:
https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings
Re-download the data in the Continuous Futures Contract chart, by following these instructions:
https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading
Date Time Of Last Edit: 2014-04-03 17:33:18
