Date/Time: Tue, 04 Mar 2025 03:55:53 +0000
Horizontal Channel with Fill
View Count: 981
[2021-11-25 07:15:16]
IntrepidTrader - Posts: 2
Hi Support,
I am trying to draw H channel with a transparent fill & have been trying to follow: Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study
I've use the Horizontal lines study & when I set "Draw Style = Fill Bottom/Top" it just fills the entire chart.
I see it is possible: https://twitter.com/merrittblack/status/1463613673797214210/photo/1
[2021-11-25 09:02:39]
User907968 - Posts: 833
The method described at the link above definitely works - example attached.
Also, the zones in the linked image look more like extended rectangle drawing tools with 'Double Extend' enabled - Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle
Date Time Of Last Edit: 2021-11-25 09:02:56
attachmentHorizontalFill.Cht - Attached On 2021-11-25 09:02:27 UTC - Size: 3.43 KB - 323 views
