Date/Time: Mon, 13 Jul 2026 12:40:46 +0000
Linked Charts
View Count: 994
| [2021-11-25 00:30:50] |
| Sami2 - Posts: 11 |
Hello, I used to link charts and was able to use the crosshair on one chart and have it appear on the same bar period on the other linked charts. I did checked all chart linkings and still not able to point the crosshair at some time/place and have it move with the linked chart since I upgraded to the latest version of Sierra Chart. Can you please help. Thank you |
| [2021-11-26 05:27:31] |
Make sure you are doing all of this correctly. Follow through the instructions here: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-26 05:27:43
