Date/Time: Tue, 04 Mar 2025 04:32:24 +0000
Micros in Sierra to route to IB
View Count: 542
[2021-11-24 20:08:13] |
arruga - Posts: 253 |
can you provide guidance to set my Sierra symbols to route via IB? can't sort out: - micro 10-year treasury - micro bitcoin |
[2021-11-26 18:45:53] |
Sierra_Chart Engineering - Posts: 18634 |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings You will find these symbols in File >> Find Symbol >> Futures-CBOT and Futures-CME respectively. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-26 18:46:44
