Date/Time: Sun, 13 Sep 2026 21:52:18 +0000
Chart Drawing
View Count: 895
[2021-11-24 18:33:22]
User837393 - Posts: 161
I'm doing a simple chart drawing on a 200 tick chart. In this case its a parallel line chanel "Tools / Parallel lines".
I want to reproduce that same chanel in a 8 range chart. To do so I went to chart setting of that chart and in advance setting #2 and in "Copy chart drawings from chart#:" I've entered the chart number of where the drawing is.
Here is the issue. The chanel doesn't seem to match where the price action is. On the 200 tick chart the current price is below the channel and on the 8 Range chart the current price is above the channel.
Am I missing somekind of parameter for this ?
[2021-11-24 19:09:56]
John - SC Support - Posts: 47854
Refer to the information in the following section and the section after it for possible reasons why you would see differences:
Lines/Rays or Other Chart Drawings Move After Drawing Them: How Chart Drawings Are Mapped Between Bars with Different Starting Date-Times
