Date/Time: Tue, 04 Mar 2025 04:08:47 +0000
Real Time data
View Count: 584
[2021-11-23 22:45:56] |
User535350 - Posts: 2 |
How do I get access to the real time Denali data feed without creating a trading account?
[2021-11-23 23:23:40] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-24 16:35:42] |
I need real time data for CME and CBOT. I paid for the Denali Data feed with real time CME and CBOT and cannot see it displayed Live.
[2021-11-24 17:17:02] |
John - SC Support - Posts: 38341 |
The first thing you need to understand is the requirement from the CME group that you have a live, funded, futures trading account that you can verify at least once a month. Refer to the following information: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Once you understand the above, then if you want to continue to get the exchanges at the non-professional fee, then we recommend the following service: Easy Solution to CME Funded Trading Account Requirement After you have the above worked out, then you can go back through the Setup Instructions for the Denali Exchange Data Feed starting at the following: Denali Exchange Data Feed: Sign the Agreements: The CME Group (Denali Exchange Data Feed Setup Instructions) Note that your agreements have not been accepted since you are trying to claim yourself as a non-professional, but without a trading account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
