Date/Time: Tue, 04 Mar 2025 03:36:07 +0000
Tenton with Phillip Capital
View Count: 1074
[2021-11-23 17:29:37]
User213263 - Posts: 14
Hello Sierra, thank you a great service.
Is it already possible to trade through direct routing Teton with Phillip Capital?
I want to join.
Thank you!
[2021-11-23 17:38:39]
Yes this is supported. You could contact Phillip Capital or the Edge Clear broker.
Date Time Of Last Edit: 2021-11-23 17:38:51
[2021-11-23 17:41:32]
commission per 1 lot = 0.05 - 0.10 cents, is it for 1 standard lot like ES or the same commission also will be for micro MES lot?
thank you
[2021-11-23 18:00:33]
What you are referring to is the order fill fee, and this will be .08USD. It is the same no matter the type of contract.
Date Time Of Last Edit: 2021-11-23 18:00:44
