Date/Time: Tue, 26 Nov 2024 02:33:26 +0000
deleting old alarms
View Count: 1068
[2014-04-02 07:54:41] |
EuropeanTrader - Posts: 290 |
Hi, I have many alarms set (via "add symbol alert" option) as seen on the screenshot How can I delete all of them at once or the ones I want ? so that I dont have to do it one by one? thank you |
ScreenHunter_41 Apr. 02 09.49.jpg / V - Attached On 2014-04-02 07:54:34 UTC - Size: 286.04 KB - 363 views |
[2014-04-03 09:16:54] |
This is documented here: https://www.sierrachart.com/index.php?l=doc/doc_AlertsManager.html#BulkEditing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
