Date/Time: Tue, 04 Mar 2025 03:25:49 +0000
New user, funded sierraaccount, data doesn't work
View Count: 479
[2021-11-23 15:40:11] |
User986433 - Posts: 3 |
Hello, could you check if my account is valid to get real time data? Seems that on account side (agreements etc) are fine, but maybe i missed something. Please let me know. |
[2021-11-24 01:34:31] |
We see you are using CQG. So this is a question we cannot answer. You need to contact your broker. Or if you want to use the Denali Exchange Data Feed, full instructions are here: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
