Date/Time: Tue, 26 Nov 2024 02:28:47 +0000
currency problems with OEC
View Count: 1006
[2014-04-02 05:55:38]
golan_82 - Posts: 24
Hi ,
I still have problems with the currency futures , I've done what you said but still
what should I do?
[2014-04-02 06:05:39]
Please let us know the symbol. If you could post an image of the chart, that would be helpful. Here are the instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
[2014-04-02 06:38:37]
6E
imagedaily.jpg / V - Attached On 2014-04-02 06:38:31 UTC - Size: 166.09 KB - 357 views
[2014-04-02 07:11:30]
You need to apply the Global Symbol Settings to that chart. This is explained here:
OEC Currency Futures Data | Post: 29645
And specifically in this section:
https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps
