Date/Time: Mon, 14 Sep 2026 14:00:06 +0000
Get a User drawn Tool's TC number with ACSIL
View Count: 820
[2021-11-23 12:57:11]
PS2004 - Posts: 49
Is there any method or function to get the Quick Load (TC) setting of a Tool through ACSIL code, which had been drawn by the User?
To be direct: I want a code snippet to run only if the last added Tool is a Retracement, and it's TC number is 7.
[2021-11-24 03:33:05]
No, this information is not stored with individual Chart Drawings.
[2021-11-24 06:59:14]
PS2004 - Posts: 49
Thanks!
So considering that this won't work, can you suggest any method, that allows me to differentiate between a retracement drawn with a Custom Drawing Tool and a Retracement drawn with a Default Drawing Tool?
