Date/Time: Tue, 04 Mar 2025 03:38:10 +0000
formatting font colour and transparency above voulme profile
View Count: 505
[2021-11-23 07:35:26] |
User274507 - Posts: 37 |
Hi, I have text above each volume profile which says the total volume for that profile. I've made the text bigger but the colour and transperency of the text make it difficult to see (I have black background text it is a light transparent grey text). Is there somewhere I can go to change it? Transperency draw style on study settings is off. thanks, Nick |
[2021-11-24 15:08:30] |
John - SC Support - Posts: 38341 |
We need to know how you are displaying the value in order to tell you where to make the changes for color/font. If you are using the display built-in to the Volume by Price study, then the Volume Numbers Text Color and Size is the subgraph that controls the color of that text. Refer to the information at the following link: Volume By Price Study: Volume Numbers Text Color and Size (SG7) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
